Vertical Hold on CRT Monitor
Look for a knob, possible on the back you might be able to adjust it. If not there might be a pop open panel on the front with buttons to let you adjust the settings on the monitor. If you dont have either of those, whack it on the top and side, it can fix older tube based systems.
