Hello, before you say this is a monitor problem it's not because I've already tried to hook it up to another monitor and the problem still occurs. Anyways , I have 2 green and purple (mixed) quite thick vertical lines down my monitor. I have tried reseating the GPU, problem still occurs. I noticed that one of the wires from the power supply to the motherboard are a bit bent in, could this be the problem? Or is it definitely a gpu problem ? These lines show up in BIOS also and I can't login via normal startup I must use safemode, however lines still appear but in normal startup it just goes to a blue screen with about 15-20 straight vertical lines spread across the screen until I restart my PC.
Here is a picture in BIOS: http://imgur.com/0FccKmd
Here is a picture in Windows login screen: http://imgur.com/4jXaFIW
SPECS:
HD 7870 XFX DD GPU
FX-8320 CPU
ASUS 990FX R2.0 motherboard
Hyper 212 evo CPU fan
600W PSU
500 GB 7200 RPM Travelstar HDD
SPECS:
HD 7870 XFX DD GPU
FX-8320 CPU
600W PSU
