Question vertical monitor
alphakush
Commendable
Dec 18, 2021
4
hello I would like to set up a vertical monitor but have no clue if you can do it with any monitor or need one that can preform the rotation I'm using now a onn 32' display filliped in portrait while that sort of works my desktop is small leaving black borders on the top and bottom and iv seen photos of a vertical setup where the full screen is used and thats what I want any info would be great thanks
rotation as in physically turning the screen 90°
or software that can turn the screenspace to the opposite resolution; 1920x1080 vs 1080x1920?
any good VESA monitor arm should allow rotating.
and graphics card control software(Nvidia Control Panel or AMD Adrenaline) allows for screenspace rotation.
rotation as in physically turning the screen 180°
i rotated the screen 90 degrees with out any VESA monitor arm its not on any stand at all just sitting on my desk i used windows display options to set it in portrait it dose work however its just it dosent use the full scrren would i need to set it to 1080x1920?
