Hi all,
I just got an HP Pavillion DV6-3064a, and the new touchpad they have is horrific. The bottom region of the touchpad acts the same as the top in that you can move the pointer around just as much. This makes it so I can only use one finger on the touchpad at a time.. which is very annoying because for 20 years I've always rested my thumb on the bottom region. I did some googleing and found a thread with the same problem, but the answers never worked.. Does anyone know a solution?
Thanks so much.
Thanks so much.
