Very basic laptop battery questions
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I am thinking of ordering a wireless Dell Inspiron 1150.
This would be my first notebook computer. I have a question about the
battery choices which are:
65 whr 8-cell versus 96 whr-12 cell.
Ok, the Dell site indicates the latter will have about 500 charge/discharge
cycles versus 300 for the former.
But, how long will these lithium ion batteries hold a charge. That is, once
fully charged, how many hours of use until they need to be charged again.
Does one last, say for 2 hours and the other 3 hours, or are they the same
in that regard.
Also, if I run the laptop on AC power, is the battery being used at all??
(Told you these were basic questions!)
Mel
> charge/discharge cycles versus 300 for the former.
> once fully charged, how many hours of use until they need to be charged
> again. Does one last, say for 2 hours and the other 3 hours, or are they
> the same in that regard.
> Mel
my wife's lasts about 3 hours. remember the Insp 1150 is a desktop
replacement laptop so it has a power hungry desktop cpu inside. If you
want long battery life you will need to look for ones with a real laptop
cpu.
But is there a difference between the batteries?
Mel
"Eugene" <nospam@columbus.rr.com> wrote in message
news:X6-dnVpMmbhxlU7cRVn-3Q@wideopenwest.com...
>> Mel
> cpu.
In article <yhDAd.40428$Fb5.1592@fe06.lga>, mel@prodigy.invalid.net
says...
<snippety>
Suggestion, outside of the battery choice (which others will, no
doubt, have better comments on than I do).
Instead of an Inspiron, get a Latitude. They may cost a bit more,
but I really think they're better built and longer lasting.
It's being charged in the background.
Keep the peace(es).
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
oops, sorry. about 2 hours for the smaller and 3 hours for the larger.
