Hello,
I have an older machine that I use to play around with overclocking on, as well as playing cs1.6, it looks like this:
CPU: amd athlon xp-m 2500+ (for ocing)
Mobo: asus a7n8x-x (1010mod2 bios)
RAM kit 1: corsair value select 2x512mb ddr400-pc3200
RAM kit 2 (old): no name 2x512mb ddr333-pc2700 (kits are used separately)
GFX: bfg 6800gt oc
HDA: wd 80gb ide
HDB: wd 200gb
PSU: thermaltake 430w
I just recently put the mobile athlon xp in it, purchased the corsair ddr400 ram to replace the older kit as well as a new heatsink (GH-PCU22-VG, url here). Ever since I have been trying different overclocks on this rig with the modded bios (currently using the cpc on bios from here). After about 3 days of different (conservative) settings and stability tests using Prime95 I have not had any luck having the system stable for more than 1-2 hours. And finally, several hours ago, while loading cs1.6 my system just rebooted and I have not been able to boot successfully into windows (WinXP SP2) since. The most success I have had is booting into windows and then having the system go completely unresponsive 20-30 seconds after windows has loaded.
Here's what I have tried:
■ I have tried going down to factory default settings on both the CPU (166x11=1826mhz) and the RAM (200mhz @ 2.5-3-3-8).
■ I have tried using the old RAM kit
■ I have tried using only 1 stick of the new kit
■ I have tried using only 1 stick of the old kit
The result is the same, I cannot boot into any Safe Mode or normal mode.
I am currently running memtest86 v1.65 off my Ubuntu 7.03 CD on 1 of the new kit sticks to see if there is a problem with the RAM, I will test all the sticks in this manner over the next few hours/days.
The only other thought is the CPC ON bios, as some have reported instability with CPC ON, if all my sticks check out with memtest86 I will try the CPC OFF bios.
However, if you have any thoughts, opinions or helpful insight, it would be greatly appreciated, thanks!
GFX: bfg 6800gt oc
HDA: wd 80gb ide
HDB: wd 200gb
