Hello.
My problem is that i can't access my router's settings and i want to open ports, the brand of the router is Inteno DG201-R1A. its a router or modem? provided by my isp, i talked to them and they said the default gateway should work, that's it
They said that they will take a look at the modem/router for 30$, but i doubt its something "broken"
I'm using a Ethernet cabled plugged into the 1st LAN port
I've tried both Google chrome and IE to connect to my default gateway
I don't use a proxy, I've tried to connect with the standard gate way (192.168.1.1) and also i pinged it and i got response, so that should be okay.
Also I've tried to completely disabled my firewall/s but i didn't make any difference.
The thing i find weird is that if i use uTorrent and puts the port that i need in the settings it works, why can utorrent temporarily open my ports >.<
Please help me! ask for any info that you need to solve this problem. Thanks!
