Very long printer cable
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
I would like to put my HP 5i50 printer at some distance from my PC.
Where can I buy a 25' USB 2.0 cable? Can two or more shorter cables be
hitched together? I hope this is possible as it would save this old
guy a lot running back and forth. Thanks for your help. Og in TX
Douglas
262
Normal USB 2.0 cables can't be used beyond 16 feet.You will need a repeater
cable to extend your range.Here is a link for the required cable.
http://www.ramelectronics.net/html/usb_active_cables.html
5@webtv.net> wrote in message
news:13024-41574254-42@storefull-3255.bay.webtv.net...
G
Guest
Guest
<OG515@webtv.net> wrote in message
Silly question but...
How does putting your printer 25 feet away "save this old guy a lot running
back and forth"?
I could understand it if you wanted to bring it closer than it currently
is..
G
Guest
Guest
You can get up to about 80 feet using multiple of the
following cables (16 feet each):
http://store.pchcables.com/16foacusbexc.html
PCH Cables is a store local to me (I buy by walking in)
and you can get just about any cable imaginable there, and
at a good price.
It's run by PC Heiden who used to have a good computer clone
store locally for a long time (across from one of Intel's
facilities in Hillsboro, Oregon).
Mike
G
Guest
Guest
OG515@webtv.net writes:
Another solution might be to get a USB print server and string 25' of cat5
cable to connect your printer (assuming you have a local ethernet).
Michael Meissner
email: mrmnews@the-meissners.org
http://www.the-meissners.org
