Very low Fps with a 1060
CHAZER2222
Commendable
Jul 13, 2016
64
Hey, I have a GTX 1060 and i'm getting 30-50 fps in csgo, major drops that hinder my performance in-game.
This is my build https://uk.pcpartpicker.com/list/qx7Z4C
Also in many other games i'm getting much lower than friend that have the same card.
What do i do? I just upgraded from a 950 and see no performance increase.
JalYt_Justin
Respectable
Jun 12, 2017
1,160
359
Make sure your display cables are connected to the GPU and not the display headers on your motherboard.
Check GPU/CPU usage and temperatures. Did you uninstall your old drivers and reinstall the new ones for the 1060?
CHAZER2222
Commendable
Jul 13, 2016
64
im looking in game and it syas GTX 1060...
CHAZER2222
Commendable
Jul 13, 2016
64
all connected to my mother board, I didnt uninstall my old drivers, how do i do that?
greenmrt
53
4
4,565
5
I know we're starting simple here, but your interconnect from your monitor is going into your GPU?
The six pin connector from your power supply to your graphics card is secure and the graphics card spins up?
You removed the 950 from your computer using the hardware manager and installed new drivers for the 1060?
https://www.msi.com/blog/pc-gaming-101-how-to-upgrade-your-graphics-card
You should be getting decent framerates with your build: http://www.userbenchmark.com/PCGame/FPS-Estimates-Counter-Strike--Global-Offensive/3680/165268.10022.Max.1080p.0
