Hey guys. A while back, I started having display problems with my rig. I would get red pixels on my screen, and eventually they turned into red lines flashing across my screen. It started off with just a few pixels here and they, and they went away after a awhile. Then, it turned into the red lines as I have mentioned. It wasn't only in Windows that this problem occurred, it even was happening at my BIOS. As soon as my BIOS screen came out, red flashing lines. So, I figured it had to have been my graphics card. I bought an Asus GTX-550ti to replace the EVGA GeForce 9800GT that I had (was due for an upgrade anyway.) Installed my new 550ti, booted up, and the same exact problem occurred. At that point, I had no idea what was going on. These were my current system specs at the time:
Asus P5NE-SLI motherboard
Core 2 Duo E8400 CPU
4gb DDR2 (speed unkown) Kingston RAM
EVGA GeForce 9800GT GPU (then put in an Asus GTX-550ti)
Western Digital 1TB 7200RPM HDD
Fatality 550W PSU
So, I gave up on my PC for a while. I had my laptop and it was enough. I was waiting until I could afford a total system upgrade before I messed with replacing individual parts. So, last week I did just that. My current system specs are:
Asus M4A88T-M motherboard
Phenom IIx6 1090T BE CPU
8gb Gskill DDR3 1600 RAM
Asus GTX-550ti GPU
Desktar 500gb (unknown speed) HDD
Fatality 550W PSU
The same problem persists, still. Through two GPU's, two motherboards, 2 sets of RAM, 2 CPU's, and 2 HDD's. The reason I changed the HDD, was that the Western Digital died between rebuilds. This really has me stumped. If anybody has any help or suggestions, they would be greatly appreciated!
Fatality 550W PSU
Asus GTX-550ti GPU
Fatality 550W PSU
