Very serious problem with my internet
gianniscfa
92
Hey guys, I have windows 10 64bit with a pcie wireless card Asus n15 . I play GTA V, on my PC, every time the game kick me cause of the internet. Say everyone left etc.. and I left alone in a server, also when I drive many players told me that I lag very very very much. Also the pages on the Google chrome opening after 1 hour. I call on my ISP they couldn't identify the problem, also told me to turn off the modem's antivirus. I done this but nothing changed. I run many tests on my PC like antimalware programs, cleaner, SFC/ scannow etc. The card it's new. I tried many cards but nothing changed. Also my modem it's 5-10 meters from my PC, so that's why I have WiFi instead of Ethernet. U suggest me to get a new router? A ethernet cable 10 meters?
My PC specs and my modem.
I5 6500
Ssd Samsung evolution 850 pro
Asrock h11m-hdv mini itx
Gtx750ti
MODEM: ZTE ZXHN H108L
PROVIDER: WIND
COUNTRY: GREECE
ADSL CONNECTION.
Cat5e is all you will need. Cat6a can handle up to 10gb but unless you drop some coin to upgrade your network you will not be able to produce that speed. Your computer and network switch/modem/router for residential use only produce 1gb through put. Your ISP will also not be able to provide you with fast enough internet to warrant any sort of upgrade over 1gb network speeds.
Does your ISP provide the router or do you? If the ISP does, they might not like (or support) anything they don't provide.
