Recently my computer crashed with a BSOD and afterward it's been booting up real slow. After the system boots back into Windows Vista x64 bit everything runs like normal. This happens during a cold boot or a regular reboot.
Once I power on the computer it hangs on the 'memory' screen where you hit 'DEL' to enter BIOS. It stays there for a few minutes before resuming the boot process. This leads me to believe it might be bad memory. I've try updating the BIOS, resetting the CMOS settings to default, booting with 1 stick of memory and the problem persist. I also noticed that when I went into the BIOS and under "DDR18V" it had failed once. After many reboot the failed message is no longer there. Any input on what I can do? I ordered a new 4gb Corsair PC 6400 DDR 2 memory and it should be arriving by tomorrow.
Intel Core 2 Duo E6600 Conroe 2.4GHz
GIGABYTE GA-P35-DQ6 Latest BIOS F9b
EVGA 320-P2-N811-AR GeForce 8800 GTS 320MB
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 x2 total of 8gb of memory
Western Digital Raptor X WD1500AHFD 150GB 10000 RPM
OCZ GameXStream OCZ700GXSSLI 700W ATX12V SLI Certified
LITE-ON 20X DVD±R DVD Burner with LightScribe
Windows Vista Ultimate X64 with SP1
*System was overclock to 3.2 ghz stable for the past year
