This is the strangest thing ever. My laptop Toshiba satellite l355d-s7915 kept shutting down during start up so I used one stick and then the other (RAM) and no luck. and then I reseated the cpu and still no luck. Then In the morning it started up fine but it seams like the keyboard is pressing stuff by it self when I type something it types a bunch of letters by it self. Like if I press the S button it will work and then it will press the other number and other letters. I checked there is no stuck keys that I can see. And also it keeps kicking me back to the windows switch users like a key is sticking.
So what is the problem why would it not boot and then overnight boot fine 3 times with no problems that is pretty weird.
