Ok, I'll try to keep this as short as possible, but here's what's been going on. A few weeks ago I went to restart my system and Windows froze before exiting, forcing me to hard reset. I didn't think much of it, but Windows was buggy and unresponsive after the reboot, so I restarted again. Once again it froze before going through with the restart, but then from there it didn't boot. Most of the time it didn't get past BIOS at all, occasionally I could get as far as the Windows login screen but then it would fully hang. Not having much in the way to test hardware, especially without a computer to make boot disks from and the like, I got it diagnosed by a PC repair shop. They tested CPU, PSU, GPU, SSDs, etc. on a testbench and narrowed it down to the motherboard. And so, I bought a new motherboard, rebuilt the system, and...
After about a day of full stability, the issue is back.
With this motherboard I do have a little more stability, I can occasionally get the thing running, but here's the extremely weird thing to me: the common factor before every single freeze is that it's when the system is relatively idle. If I, for example, have a YouTube video playing, or have a benchmark or test running, or am playing a game, the system will run. But once I stop? It will freeze within maybe 30 seconds. This seems to me like it might indicate that there's something weird going on with the voltages when the CPU starts idling, or something to that effect, but I'm not knowledgeable enough in this sort of thing to be able to detect it. The voltages seem normal in
Most of the time the freezing occurs without a crash so I'm not even given a dumpfile. Or it happens before getting to Windows at all. Every now and then I've gotten a BSOD, but nothing that gives a whole lot of information. The failing driver is always
Here's what I have done:
I've updated the BIOS, I've reverted the BIOS to older versions. I've installed and uninstalled and reinstalled chipset drivers. I have run
So, what do I do at this point? It seems highly unlikely to me that two motherboards would be bad in the same exact way, so I'm mostly ruling that out. The fact that the freezing occurs in many cases before ever booting into Windows, or even when I tried booting into a Linux live USB, rules out a boot drive issue or some sort of drivers issue. This leads me to think that the problem is with the CPU or PSU, though as I understand it PSUs typically don't fail in that kind of way. The computer has otherwise been just fine to me for the past two years.
And finally, the specs:
Thank you so much to anyone who helps out. I'm losing my mind here, this has all been so frustrating and disheartening and I don't have the money to just start wildly dumping into possible solutions right now. Getting halfway to just becoming an "off the grid" kind of freak by this point.
HWiNFO64
, but since I can't see what's happening the moment of the freeze who can say for sure. I will say that one of the CCD sensors is always a good 10–15℃ hotter than the other one, but I don't know, maybe that's just the 5950X for you.Most of the time the freezing occurs without a crash so I'm not even given a dumpfile. Or it happens before getting to Windows at all. Every now and then I've gotten a BSOD, but nothing that gives a whole lot of information. The failing driver is always
ntoskrnl.exe
, which as I understand it doesn't shed much light on the true problem. There's nothing of use on the mobo debug code.Here's what I have done:
memtest86+
and testmem5
for multiple passes without issue (testmem5 occupying the CPU with something to do meant I got to leave the system running for hours). I've uninstalled and reinstalled any drivers I could think of and unplugged my audio interface, DAC, PCI capture card, every other USB device I have. I've turned PBO fully off in the BIOS, I've kept memory settings stock instead of clocking them to XMP speeds.So, what do I do at this point? It seems highly unlikely to me that two motherboards would be bad in the same exact way, so I'm mostly ruling that out. The fact that the freezing occurs in many cases before ever booting into Windows, or even when I tried booting into a Linux live USB, rules out a boot drive issue or some sort of drivers issue. This leads me to think that the problem is with the CPU or PSU, though as I understand it PSUs typically don't fail in that kind of way. The computer has otherwise been just fine to me for the past two years.
- AMD Ryzen 9 5950X
- ASUS ROG Crosshair VIII Dark Hero (orig. mobo was a Gigabyte AORUS X570 Master)
- G.Skill 2x16GB F4-3600C16D-32GTZRC | Trident Z RGB DDR4-3600 CL16-19-19-39 1.35V
- Gigabyte Vision 3080
- 2 WD SN850 NVMe SSDs
- 1 8TB HDD I don't remember
- Seasonic FOCUS GX-850, 850W 80+ Gold PSU
