I have a problem with my main monitor and it is like one I have never seen before. I have had this monitor for 7 months now and it just started doing this. Sometimes, the monitor is all washed out in white and you can see streaks of white if there is a black image over the monitor. It is very hard to explain what it is that I am seeing. Its almost like the monitor is very foggy and the colors get distorted. The strange thing is it doesn't stay like this and will eventually fix itself but the problem then comes right back the next day. What I have found out is if I take a screen capture, the monitor looks normal which tells me it has nothing to do with the color settings. Another thing I have found is if I turn the monitor off then back on, it goes away, but then after 30 seconds it "grows" back again.
I have attached a picture showing it the best I can. I have 2 monitors and the one on the bottom is the one with the issue. Both monitors have the exact same picture (which is just Discord)
