Very Strange Problem
vwcrusher
712
24
18,995
Experiencing a very strange behavior after switching out PSU and case, all other components are identical as before.
After working on the PC, I typically put it in sleep mode, and when I want on again I simply hit a key and it wakes up. Now when I do that the monitor turns on for a second and then turns off! I cannot get it to come to life other than reboot the system.
Honestly, all internals have not changed, but clearly something did; please help.
For the record the old PSU was a XFX Pro550W Bronze; the new is a Seasonic Focus+ 650W gold. The old case was a Xion Onyx XON-303; the new is a FD Define R6.
Again thanks for the help; this is weird.
Figured it out!
My bad actually; there are two PCIe slots in my MB and I placed the GPU in the slot that provided the best air flow; I didn't realize it was a slot for SLI.
After moving the card up to where it originally was in old chassis.....works like it should.
DUH.
What are the rest of your system specs (CPU, MB, GPU, Etc.)?
Thanks for the reply; below is the rest of the system:
Intel i7-3770 3.4GHz
Cooler Master Hyper 212 EVO
ASUS P8H77-V MB
16GB DDR3
Samsung 256GB 830 SSD (OS and apps)
1TB WD Black HDD 64MB cache (data)
Auria 27" EQ276W (2560 x 1440) Monitor
Perhaps the timing of the events will help:
After putting it in sleep, the fans stop and the monitor turns off (red led). When I hit a key to wake up, the fans start up, the monitor led goes green, then the screen notes "no signal" for a second flashes and then turns off. Could it be a GPU issue?
Went into bios and could not find anything related to sleep and hibernation......ugh.
I wonder if the new PSU doesn't apply power to the GPU right away causing the monitor to shut down?
They might be referred to as "C6/C7" states. IDK about the GPU not "waking uo" in a timely matter.
Figured it out!
DUH.
Glad you got it sorted out!
