Very strange video glitch in power point (slide show mode)
Gabriel Eduardo
Hello eveyone. Well, I'll try to be as short and clear as possible. I recently bought an Asus g750 jz. Soon after I installed office and began making a presentation in power point, but I noticed something really weried when I inserted a video. Whenever I enter into slide show mode in the slide that has de video and play it, it begins glitching or lagging or... I don't really know how to call that effect (I inserted a link to a video that shows the problem). So I haven't found anything about it (probably because I don't even know how to describe the problem) on line. I would really appreciate your help:
Some additional data:
Here is the link to the video that shows the strange glitch https://www.youtube.com/watch?v=taGbpo03Zpg&feature=youtu.be
It only happens in the slide show mode, when in normal mode (creating the slides) the video runs perfectly.
I have set in my nvida control panel that the powerpoint always uses the GTX 880M GPU (but for the record I have changed it to the integrated intel GPU that the asus g750 jz also has and the problem remains).
Thanks in advance for your support.
http://
Well, just want you to know that I solved the problem, a support member from Asus gave me somewhat the answer. I just downloaded silverlight and re updated (because I already had the latest version) my nvidia driver version. The problem is no more, so, thanks any ways, and if you have the same problem, use this solution, it works.
