Hi
I bought a new Spectre x2 2 years ago but then went overseas for 18 months and left my Spectre x2 on the shelf at home. I'd only used it 40 hours and it worked perfectly on charge and on battery.
I turned it on this week and it operated normally except an error message on the taskbar battery icon "0% available (plugged in, not charging)" Also the LED light is constantly blinking white light and when i unplug it it immediately switches off.
I ran apower diagnostic through UEFI and the AC Adapter has passed but the Battery is coming up as NOT INSTALLED.
I have then:
aaaaaand it still says "0% available (plugged in, not charging"
need help
I have then:
- run hard resets for devises that don't have a disconnectable battery x 4 (the CMOS 502 error message comes up each time i do a hard reset however it autocorrects itself and doesn't appear again if i boot up normally)
- updated Windows 10 64 bit with ALL updates
- ran a driver check via HP Assistant saying all drivers installed
- device manager went to firmware and updated driver (said it's the latest version)
- went to BIOS and checked yes it's version F.34 latest version
- wound back the BIOS to previous version in case latest BIOS install was corrupt
- reinstalled latest BIOS
- did Windows system troubleshoot on Power settings
- did UEFI checks on all hardware
need help
