hello all
i currently have an intel core 17 920 running at 3.5 ghz.
i am haveing alot of trouble with temps though🙁
my idle temps are 40 degrees celcius and load is close to 80 when using prime
everything is stable as i have increased vcore ever so slightly (in bios the next choice up up from the normal vcore)
is ther any err... things i should turn off in bios to reduce temps.
i will change the thermal paste on the cooler aswell in a moment whe i get the time and i will repost the temps then
My specs : mobo ex58-ud4p
cpu - i7 920 at 3.5ghz
gfx - 4870 x2
cpu cooler - thermalright ultra 120 extreme 1366 ( fan used is the fan from the thermaltake typhoone vx cooler)
gfx - 4870 x2
