Hi there guys.
I've been running a leak test on my water cooling loop for 6 hours. There are no leaks so far but it is very warm. It's so warm that it would be incapable of cooling my AMD 9590 CPU. I'm using an 'Alphacool NexXxoS Cool Answer 120 D5/UT - Set' with a 'Magicool 1/4" Thread Inline Watercooling Filter'. The D5 pump is set to max speed (5/5).
The only thing receiving power is the pump itself and the PSU, of course, as it is a leak test. The loop is inside the case and is set up the way I would set it up when my PC is up an running.
The entire loop is very warm from the radiator to the reservoir. Are there any ideas of what could be causing this? Many thanks in advance.
