A wall of text is about to go in, be prepared:
So i have a weird major issue with my Motherboard right now. It doesn't boot when there isn't a bootable USB device(any, whether it's a windows boot USB, a Ubuntu live USB or a memtest bootable USB).
What happens is that when it's not attached, and i boot the system up; the screen stays black and the HDD activity led gives a pattern of about 3 seconds off and then a short flash indefinitely. Nothing else happens...(keyboard and mouse lights do not go on at all)
Now when i attach the USB stick, the systems boots and the BIOS gives me "Previous Boot failed, load optimized defaults and boot" I don't think this has to do with a bios setting whatsoever and it's been on optimized defaults since forever now. Now Windows boots normally and no further issues arise(like literally nothing)
I've reinstalled Windows 10 completely fresh(from USB using UEFI and GPT partition table and copying over Windows 10 setup files directly from the ISO)
It all started with a random BSOD(irql_not_less_or_equal) of the Intel C220 SATA/AHCI driver. This caused my system to crash, and Windows to fail booting(INACCESSIBLE_BOOT_DEVICE)
I tried resolving this by using a recovery usb of Windows 10 and use the idem command to restore the Microsoft SATA driver. After i did this, i restarted and the system completely failed to boot(causing the symptons i said before). I've tested alot of things: RAM, GPU, SATA devices(even tried unplugging all SATA cables in the machine, which did not work)
I've ran Memtest86 v7.1 through 1 pass and no issues arose, not even the hammer testwhich did give me a note(no error) saying that my "RAM may be vulnerable to high frequency row hammer bit flips"
I've all confirmed that these are not the problems.
Is there anyone that knows how i might solve this issue? I have the feeling the driver issues from before causes the SATA/AHCI controller to behave improperly(on hardware level) and also causing device initialization to fail in certain cases.
