Hi,
I installed a new NVMe drive in my system and I have a very weird problem.
After several hours/reboots the NVMe drive just disappear from the system, I cant see it in the bios and the computer wont boot.
I have no idea what causing that and the computer can be fine for several hours and then when I reboot it just stuck at the bios because the drive is not found.
The weird thing is that I have to MANUALLY reconnect the drive even though the drive sits perfectly with his screw.
While Im using the computer every thing is normal and the drive is usable .
I have no idea what to, Its so annoying to reconnect this drive because I have to disassemble my GPU and CPU cooler.
My motherboard is Z370P-D3(which should support NVME), The drive is Intel 660p 512GB.
(I forgot to mention that the BIOS is updated)
