[SOLVED] VGA and DRAM not working
Mar 5, 2019
4
Hi every one. I've recently completed a PC build and ran into some problems. My motherboard indicates that the DRAM and VGA are not working properly, and is not displaying any video on my tv. I could use all the help I could get thanks
Here is the specs.
Power supply: corsair RM850x
GPU: ASUS RTX 2060
MOBO: X370 power gaming titanium
CPU: AMD ryzen 7 1700X
Memory: DDR4 4x8 fb 32GB 3200MHz
ryzen 7 1700X
Maximum memory clock speed is lowered when using more than 2 memory slots.
Memory Configurations
Single Rank 2 DIMMs DDR4-2666
4 DIMMs DDR4-2133
Double Rank 2 DIMMs DDR4-2400
4 DIMMs DDR4-1866
https://en.wikichip.org/wiki/amd/ryzen_7/1700x
Newer model AMD Ryzen 2000 series processors featured an improved memory controller which allowed the next higher clock speed over earlier 1000 series models such as the 1700X.
Always list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
How are the rams populated on your motherboard? Have you tried running the entire system while breadboarded? Are you on any aftermarket cooling?
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
All four sticks are inserted I'm sure. Breadboarded? I'm sorry I'm still fairly new to this.
ryzen 7 1700X
4 DIMMs DDR4-2133
4 DIMMs DDR4-1866
You didn't reply with your specs like I've asked you to. Read this.
Sorry.
CPU: AMD RYZEN 7 1700X
Motherboard: msi X370 Xpower Gaming Titanium
Ram: Corsair vengeance RGB PRO DDr4 4x8 GB 32GB
SSD/HDD: Seagate barracuda 1 TB hard drive
GPU: ASUS geforce RTX 2060 GDDR6 6Gb
PSU: Corsair RM850x
Chassis: Corsair Carbide Series Spec-omega RGB (white/black)
OS: windows 10 64bit
