VGA Cable as PCI-E manual states
terminator123
830
Hi
I have an EVGA 850W 80+ Gold power supply.
There is no PCI-E express cable.
However, my manual says PCI-E VGA cable.
And I have 4 sets of cables tagged (VGA) < which is what it says in the manual.
Must the PCI-E power cables for a graphics card I'll be putting in be them?
All it says it VGA on them, and I HAVE NOT got any which sayd PCI-E, this is a new power supply, i finished the build last week.
If you ask also I HAVE NOT lost any wires.
Yes, those are the ones you use to power your graphics cards. Different manufacturers sometimes use different terminology, but yes, those 'VGA' labeled cables are the PCIe power cables.
Right, I was worried because I thought I was missing cables.
You have been of great help, thank you ever so much.
