Zalman does have very good VGA coolers which work fanless while still being better than ANY Orb cooler.
But mind you: they are HUGE, and occupy the closest PCI-slot.
You can check them out at the following URL:
http://www.zalman.co.kr/english/product/zm50-hp.htm
Only look at the ZM50-hp and the ZM80A-HP (not the ZM80-HP).
As you can see, they are big, and not really cheap,
but excellent for cooling a GF 4MX.
Don't look at their smaller models; those are intended for video chips which don't produce a lot of heat, such as the Kyro series of chips (which I have).
With these Zalman coolers, YOU CAN OVERCLOCK AS MUCH AS YOU CAN. Heat will no longer be a problem, as long as there is enough airflow in your PCs case of course.
And because they're fanless, your noise problem is solved too.
But mind you, I think that the bigger model, the ZM80A-HP, also covers the memory chips, so don't use RAM sinks yet!
But I'm not entirely certain about this, so check it out at their website.
Hope this helps.
Greetings from Belgium!
Carl
