Question Vga debug light on and no display
May 22, 2019
5
I jus built my first pc
Spec
R3 1200
Msi B450m gaming plus
2x4gb ram
Ssd
Gigabyte rx 460 super oc x8
And i put all the components together and everything spins the case fan the cpu fan and the gpu you fan but 5 seconds later the vga debug light turns on and no post all i see is a under score in the middle of the screen then i tried another card a rx 470 which takes pcie power and the same result the gams spin but no post. Please help me and thank you for reading
Satan-IR
1,059
87
11,740
143
The Gigabyte RX 460 super oc x8 doesn't need a PCIE power connector, right?
Having tested with another card and getting the same result the board might need a BIOS update.
Not sure if you can do that easily without a display output.
Edit: Anyway do not attemp a BIOS update if you're not familiar with the process as if the update process goes wrong you might end up bricking your board.
Satan-IR
1,059
87
11,740
143
Are the mouse and keyboard PS/2 or USB?
If USB, were the mouse and keyboard plugged into the motherboard I/O panel on the back or to front case USB connectors?
If so the front case USB connector/ports might have a short.
