VGA Led Lit
Apr 19, 2018
Hello all,
This morning my computer would not turn on it displayed VGA light on the motherboard, searched the forums and found out it could be a GPU problem. I simply flicked the power switch at the back after shutting off and removed the PSU for a couple of minutes, plugged it back in then it began to work again. So that leads me to assume if the GPU isn't dead, could it perhaps be the power supply? Never gets overclocked/overheat and has liquid cooling installed.
Specs:
Intel core-i7-6700
GTX 1060 6GB
Bazooka plus b150m
16gb ram
Thanks,
