VGA Max Share Memory 1024 (MB)
MysterySlender
Commendable
Jul 17, 2016
44
Hey,
I just bought a new GPU (Zotac GTX 1060) and than I saw in my MOBO specs "VGA Max Share Memory 1024 (MB)"
What does this mean? Will it use only 1gb out of 6gb that I have in my new GPU?
No, you will be able to utilize all 6gb of the GTX 1060 VRAM.
The shared memory is most likely your onboard intel GPU that can only use 1gb of your system memory, so it has nothing to do with your dedicated GPU.
You will not be using the onboard intel GPU, so don't worry about it.
