T TraXon Prominent Feb 24, 2017 35 0 530 Jun 14, 2017 #1 I have a vga 19zoll monitor with vga connection and i want to buy the msi gtx 1060 6gb X graphics card what cable can i use to connect my monitor with the gpu?
Solution DRagor Jun 14, 2017 You will need active DVI-D to VGA adapter, and then use VGA cable from adapter to monitor. Something like this: https://www.startech.com/AV/Converters/Video/DVI-D-to-VGA-Active-Adapter-Converter-Cable-1920x1200~DVI2VGAE
DRagor Polypheme Jan 23, 2017 9,098 813 65,440 Jun 14, 2017 Solution #2 You will need active DVI-D to VGA adapter, and then use VGA cable from adapter to monitor. Something like this: https://www.startech.com/AV/Converters/Video/DVI-D-to-VGA-Active-Adapter-Converter-Cable-1920x1200~DVI2VGAE Upvote 0 Downvote Solution
