Question VGA or HDMI on computer won't display to monitor
Feb 17, 2019
I was taking apart my old computer and decided to test two 2gb ram sticks on our current one. I put the two in and tturned on the computer. It then cutoff imeditally. I switch the ram back out and turned it back on, and now the VGA and HDMI don't work.
Not sure if the ram caused the problem.
I recently tried to check if two 2gb of ram from an old desktop worked on a different pc. When I put the ram in (most likely the wrong way) the computer short circuted and turned off after half a second. A smell was being emmited afterwards.
After I took out both the ram sticks and put the other ones back in, both were 4gb, the computer turns on and appears to be working, but, the computer itself is not booting up.
I tried clearing the CMOS by taking out the battery on the motherboard, but it did not solve the problem. Not sure what else to do.
Specs:
Pre-built
Asus Essentio Desktop Pc
Model: CM6830
PSU: 300 watt power adaptor
GPU: NVIDIA GeForce GT 530
CPU: I7-2600
Processor Socket: LGA1155
8gb of ram with 12600u speed
Not sure what exact motherboard I have
