Hey all.
So I'm trying to set up a second monitor but the problem is that the VGA port from the motherboard has no signal when I plug it in, I'm currently using DVI-I for my primary monitor. I know a separately installed graphics card will turn off motherboard's integrated graphics but I used to be able to run it with no problems, before I moved overseas. (Also tried using an adapter for VGA to HDMI, switching cords between 2 monitors, going into BIOS to enable VGA monitor)
I7-3770 3.40GHz
8G RAM 64bit
GTX 660
Primary Monitor- ASUS VH222 Second - BENQ g2000wa
BIOS ver.0906
I need more solutions before going to the conclusion of switching a new motherboard or another graphics card.
Thank you.
I7-3770 3.40GHz
8G RAM 64bit
GTX 660
BIOS ver.0906
Thank you.
