Vga port on computer to vga port on tv
Chancegrant
Commendable
Jun 23, 2016
4
I have connected my Sharp Hdtv to my HP desktop using the vga ports on both devices. When I boot up the computer, the load screen is displayed on my tv. The connection terminates right before the computer has completed the loading process. Any ideas as to what I can do to fix this issue?
I set it up for the 1280 x 720 resolution, which should work with the tv. The resolution seeing on the computer range from 1024 x 768 to 1920 x 1080. I'm also not sure what the resolution is on the TV as it is a couple years old and there are no markings or Manuel for it.
I've tried using 800 x 600 (lower setting on computer), 1280 x 720, 1280 x 960, and the 1920 x 1080 resolutions on the computer. Each time the computer is loading, the tv (32") display works but then loses the connection with the computer before it finishes loading. I have to switch the vga cable back to the original LG monitor (20") in order to change the settings. I did get it to actually load the main computer screen the first time that I tried, but it cut off after a couple of minutes that time when I was adjusting the resolution and have been unable to get back there.
