Hi Everyone,
I recently built a computer. However I am having real difficulties with the VGA drivers or the ASrock H97 Anniversary motherboard. for some reason it keep stating every time I try to install the drivers that, 'Your computer does not meet the minimum requirements for installing the software."
Has anyone had a similar problem and found a workable solution?
Also there is another error message that occurs if the computer is turned on before the screen (connected via VGA). After boot up and just after logging in with my password into windows the error message flashes 'the object invoked has disconnected from its clients' then the screen goes black, re-adjusts and everything is then fine. Do you think these issues could be related?
Many thanks in advance for any help and thoughts offered.
Kevin
System specs;
Windows 7 Home Premium 64-bit
Intel I5-4460 LGA 1150 3.2GHz, 6MB Cache
ASRock H97 anniversary motherboard
2x2GB Dual Channel Ram
128GB SSD
1TB WDC HD
Gigabyte GT610
Kevin
System specs;
128GB SSD
1TB WDC HD
Gigabyte GT610
