Question VGA status led ON , but GPU is working properly.
Redmore
17
Good day everyone! First of all I want to say that this community is wonderfull and full of excellent advices! Well done, cudos, bravo! So I recently finish a new build, successfully installed OS , updates and drivers. Bellow is the parts list:
CPU: Intel Core i5-14600K
MB: Gigabyte Z790 Aorus Elite AX (1.1)
GPU: GIGABYTE RTX 4070 Windforce 12GB OC
RAM: Corsair Dominator 2x16GB DDR5 6000
PSU: Corsair RM850x (80+ gold)
CPU COOLER: Corsair iCUE H150i ELITE CAPELLIX XT
CASE: Corsair iCUE 5000d airflow
MONITOR: Samsung Odyssey G5 32.0" 2560 x 1440 165 Hz Monitor (LS32AG500PPXEN)
Pcpartpicker link: https://pcpartpicker.com/list/ncj26D
But I run into a very weird issue. Actually two weird issues.
The first issue is that when I power the computer on , via the power button, the RGB LEDs on the motherboard flash momentarily before it boots up normally. Now, this is more of a nuisance and a problem, but I can't help but wonder if it's supposed to work like this or is there a short in the system that will eventually make the whole thing explode before my eyes.
The second and more concerning issue is that the VGA status led on the MoBo stays on if I power the system up BEFORE I power up the monitor. The monitor is hooked to the GPU with the included Display Port cable, that came with the monitor. (GPU didn't have any cable in the package) The sequence of actions is this:
1. Turn the system on
2. Turn the monitor on
3. Status LED on MoBo go on their cycle and the VGA led stays on
4. Monitor displays "no signal found" message
5. BIOS press del to enter screen shows up and
6. Boots normally into windows
7. The VGA light is still on and won't go off unless I do a restart.
Now I tried different ports to see if it's a faulty port, but I got the same result from all 3 of them. I used the HDMI cable and the problem was gone! But the HDMI won't suffice for me, as I want something that can support the 165 frames refresh rate. I also re-seated the GPU in it's slot, and changed PCIe power cables (between the ones that came with the PSU). Still had the same issue.
Mind you, the GPU is working properly even if the led is on, Windows identify the card and the monitor. I run heaven benchmark on ultra setting 1440p and got 130 fps average. With max GPU temp at 58 celcius.
I understand that this could be just a glitch , but I can find anything online , apart from an Nvidia tool fix for display port that is only for the 10series and doesn't include 4070. Any thoughts?
update the BIOS of the motherboard
I updated it to the FG version which is the last stable version for my CPU. The new FHc is still beta (that's what the "c" stands for right?), so I am not very keen on doing that. But thanks for the suggestion!
Would try the FHc, you can easily flashback the BIOS if it´s getting "bricked"
also the update is officially posted since November, usually if something gets wrong, such a BIOS would disappear quickly
all connectors plugged into the GPU and PSU (both sides)?
Reactions: Redmore
Yeah all the way plugged in, checked for bent pins, bad connections, tried different PSU pcie ports etc. Will try the BIOS update then to see what comes of it.
did you connect the monitor to the motherboard or the RTX 4070?
maybe try a different video cable/port
Connected to the GPU card definitely. The card has 3 D-ports and 1 HDMI. All the D-ports give the same result, but the HDMI doesn't. I am beginning to think it's some sort of display port driver issue on my monitor. If that sort of thing even exists.
did you try the same DP cable? Maybe the cable is not a good one
To he honest it never crossed my mind that it might be a faulty DP cable, I mean it came with the brand new monitor, so you expect at least some level of quality. I am going to grab a new one to try after I get home from work.
similar thread, might be a communication problem while starting. Monitor might be in sleep or searching for sources. Try selecting DP in the monitor as source manually instead of auto
Reactions: Redmore
Tried the new DP cable results were the same. Funny thing is that I can see the BIOS screen, unlike the thread you posted. I have no problem booting or with POST at all, it's just that the VGA led is on all the time. Also I did a reboot without switching off my monitor and the MB went through the status check and the VGA was cleared! So I tested turning on the monitor before powering the system on: the status check started, went to CPU led, RAM led, hanged for a second on the VGA led and finally went to the OS led. Got to the windows screen and every status led was off!
It makes me think if there is a delay on the monitor it self , maybe it takes a little bit longer to startup comparing to the system, and the MB can't find it during its initial startup check. Pretty weird stuff.
