VGA Subwoofer to 3.5mm Jack?
Inoeie
12
So Ive got a sub woofer that takes a VGA in and power, but the cable it comes with has 2 speakers on it which I dont need. So would I be able to cut those off even though the volume control is on one of the speakers so I might need to short it? Or can someone just show me where to buy a 3.5mm out to VGA in so I can just wire it inline with my current speakers.
this would not work did you try to mute the 2 satellite from os and keep sub only i would not cut the cable might cause issue to sub after since it have amp in it with fuse.
Dell A525 Zylux
But what is that cable called because I dont need the satellite speakers and only want the sub.
