Archived from groups: rec.video.desktop (
More info?)
"WEBPA" <webpa@aol.com> wrote in message news:20040428183905.04086.00000619@mb-m12.aol.com...
> >Toshi1873 wrote:
> >>> Rick could try masking off the bottom few lines in his
> >>> video editor.
> >> That's pretty much what I do in VirtualDub during the
> >> filtering stage. Add a resize filter, edit the crop
> >> settings to remove the 4 or 8 lines from the top/bottom,
> >> then change the resize settings to letterbox the image
> >> back to the original size. End result is a centered
> >> image with thin black bars at the top/bottom and no
> >> scaling issues.
> >If you capture full-height, interlaced material, you need
> >to be careful about this approach in order not to screw up
> >the field order. (Numbers that are divisible by 4 are good
> >and safe even if you do the recentering trick, all others
> >may cause unexpected results on interlaced displays.)
> >Then again, do you really _want_ to move the original
> >center point of the image? The original tv images were
> >probably composed with the expectation that the center
> >point stays where it was when the production was
> >originally made.
> >znark
> Right. And in addition, it is kind of stupid to discard parts of the signal
> that are designed to be invisible when displayed on a TV display ("overscan").
> If your end-use is a computer monitor (which displays all lines of the original
> video), then a different argument can be made. But for DVD/SVCD or anything
> else to be displayed on a TV monitor...you're destroying useful information by
> cropping the head switching noise.
> webpa
Webpa, what's the easiest/most straightforward way of discarding
this head switching noise, assuming end-use is for a computer
monitor? I have a bunch of MPEG-1 files I'd like to fix but I'm
getting a bit lost with all the different software, filters etc.
Thanks,
Rick
