Question VIA USB 2.0 Hub: "This device cannot start. (Code 10)" and "STATUS_DEVICE_NOT_CONNECTED" ?
BlueFeather
Commendable
Jun 21, 2019
9
VUSB\VID_2109&PID_3431&REV_0420
Desktop PC
Motherboard MSI X470 GAMING PRO CARBON (MS-7B78)
Operating System Windows 11
64GB of Ram
2 2tb ssd and one 1tb hdd
CPU AMD Ryzen 7 2700 Eight-Core Processor
I uninstalled and reinstalled the drivers and it seams to have fixed it'self for now
but thos could be the famous last words that jinx it...
There shouldn't be any USB drivers for win 11. Windows should look after it all.
What drivers did you reinstall? It should be the chipset drivers if anything at all.
I don't see any mention of VIA on here
AMD® X470 Chipset
  • 1 x USB 3.1 Gen2 (SuperSpeed USB 10Gbps) Type-C port on the back panel
  • 1 x USB 3.1 Gen2 (SuperSpeed USB 10Gbps) Type-A port on the back panel
  • 4 x USB 3.1 Gen1 (SuperSpeed USB) ports available through the internal USB 3.1 Gen1 connectors
  • 6 x USB 2.0 (High-speed USB) ports (2 Type-A ports on the back panel, 4 ports available through the internal USB 2.0 connectors)
AMD® CPU
  • 4 x USB 3.1 Gen1 (SuperSpeed USB) Type-A ports on the back panel
https://www.msi.com/Motherboard/X470-GAMING-PRO-CARBON/Specification
Even looking at windows 7 area, the only drivers are AMD USB drivers. No VIA?
https://www.msi.com/Motherboard/support/X470-GAMING-PRO-CARBON#down-driver&Win7 64
i found the win 8 drivers VIA_XHCI_Driver_V4.00B_WithAp.exe
sofar the issue seams to have fixed at least i think they were win 8
yeah, those are win 8. According to search results anyway, could be relabelled win 7 drivers too.
hard to tell if they for your board though as MSI don't list win 8 on the board drivers list.
VIA no longer make it - https://www.via-labs.com/product_show.php?id=51
I can't find any links to Via and that motherboard. It is very strange but if it fixed it, shrug?
Win 8.1 has USB 3 built in, same as 10 did, but I do recall needing Via drivers on some boards.
I have to go into device manager after every reboot and manual search the drivers from the let me pick off a list,
the product is a SIIG Legacy and Beyond Series PCIe to USB 3.0 7-Port PCI Express Card I got off of Amazon that
my question is why make a product just to not support it after a month
any recommendations on a replacement 7 port USB card for PCIE?
well, that explains where Via comes in
Chipset: VIA VL805 + VL813
https://www.siig.com/usb-3-0-7-port-ext-pcie-host-adapter.html
if you had mentioned that a few posts ago I would have realized.
its always possible they aren't aware device doesn't work with win 11.
there is one made by cruxtec but it uses the same two chips.
I could almost bet you the 7 port PCI card by Startech also uses same 2 chips.
i can't tell with this one but probably the same chips - http://my.orico.cc/goods.php?id=6585
why do you need 7? can't you use a USB hub?
I just prefer internal to external hardware whenever possible
I already have enough cables to manage and don't want to chance overloading a circuit breaker
looks like Oricho diver page just redirects to the front page and the email them form has a JavaScript error
can't even bother to hire a competent webmaster...
