So, i just noticed, when i put the ear to the back of my case where the exaust fan is i can here what sounds like noise a HDD would make, so then i took the back panel off and put my ear to the other side of the motherboard the back and i could hear it most clear in this place, i was hoping it was the fans or something , idk still could be something to do with pump or fans in radiator? i guess, but to me seems like it is isolated to where cpu is, and to where the pumps connect to the mount over CPU, got no clue what it is, my pc seems to be running normally as far as i can tell. i checked temps at IDLE still the same as they always where around 30 degrees in the bios and like 35+ when in windows, not sure if the windows temps increased or not but seems about the same.
It is really really really annoying, even with the side panels on i can still here it cause it is so distinct it is like a higher pitched sound than a HDD clicking would make. Another thing i noticed was i heard some like swooshing winding up sound comping from somewhere a few times.
But this sound is really bothering me it never stops now, and overrides everything else.
I cant find anything not working correctly. When i was in by bios i could see the AIO pump was running like 2000 RPM + in the bios the actual liquid cooler i have is Be Quiet ! silent loop 240 mm cpu is core i9 9900k.
Im not aware of any software i can download for this specific liquid cooler to check if anything is wrong.
I haven't noticed anything wrong with temps i checked idle temps in HWID they where always around that, i did see them jumping a bit not sure if its normal or not.
Would appreciate some help as im not sure if something is wrong. Posted HWID images below. Im concerned either the pump or cpu is dying or something is wrong but i cant find anything wrong.
I downloaded the intel processor diagnostic tool, when it was in the iprime phase prime number, and it was at full load and max mhz temps did go to around 74-76 degrees. for like 30 seconds. During cpu load test phase was around 60-65 degrees Results from intel processor diagnostic tool are below .
Only thing that happened is i upgraded my old card to a rtx 3070, some months ago, installed a m.2 SSD NVME , My psu is a straight power 11 so all of that it will manage easily. Im wondering when i installed windows maybe it did something stuffed some setting up only thing i can think off.
Here are screenshots from HWID when pc is on idle.
