[SOLVED] Vibrating sound
Nonkii
Proper
Jul 27, 2019
469
11
185
Hey. Everytime I turn on my pc I hear a vibrating sound and it goes away or I just get used to the sound. Is it something I should worry about?
delaro
Splendid
Herald
You could also check to see if any of them are loose. Take the side off and start the machine up then just put your finger on the frame of each fan one at a time to see where the noise is. It's possible it could also be loose.
Nonkii
Proper
Jul 27, 2019
469
11
185
Alrighty. Thanks
