Danvic Nov 25, 2021 66 0 30 May 25, 2022 #1 Can a powered down (not in use) external hard drive can be damage by a vibration? How sensitive is external hard drive to vibration? Thanks.
Solution lvt May 25, 2022 Vibration is bad for any device with moving parts, not only HDD. But you should not be too concerned about it when your HDD is not running.
lvt Honorable Apr 19, 2021 3,738 610 10,940 May 25, 2022 Solution #2 Vibration is bad for any device with moving parts, not only HDD. But you should not be too concerned about it when your HDD is not running. Reactions: Danvic Upvote 0 Downvote Solution
H hotaru.hino Glorious Sep 1, 2020 9,822 3,569 46,090 May 25, 2022 #3 It depends on how strong the vibration is, but I think it's safe to say if a hard drive can survive a trip on a semi-truck and the manhandling of couriers, it should be fine. Reactions: Danvic Upvote 0 Downvote
