[SOLVED] Victoria freeware mounting disk problem.
4
So I used Victoria freeware to scan D: drive and a portable HDD, both are WD drives and working normally.
Problem is now after scanning the disks are unmounted and I cannot find anywhere in the software to mount them back in, the scanned disks are nowhere to be found but the info list in the program. I did not choose erase data option. How can I make the computer recognize these disks and use them again without losing the data?
Edit: They are also found in Disk Management. Can I use this and how to mount these disks without losing data?
Disk1 is unallocated.
You could try partition recovery with minitool partition wizard free.
Can you show Disk Management screenshot with size adjusted, so all disks are visible?
Can you show screenshot from Disk Management?
(upload to imgur.com and post link)
Hello SkyNetRising, my apologies for such a delayed reply as I was away. Here is the screenshot of Disk Management, Disk 1 is one of the two that I scanned, the other is not shown here. Any way to mount them back in system without losing data?
Thank you for your previous reply.
