Video Card advice for newbie's first pc build.
si1
11
Hi there,
I have pretty much decided on the spec for my first build apart from the graphics card. Have found both these cards at the same price on special offer. I am on a tight budget.
VTX3D R9 280 X-Edition or
Sapphire R9 280 Dual-X OC 3GB GDDR5
Which would you recommend for media and gaming?
this is my build list which may help.
Case - NZXT Source 210 elite (white)
Power Supply - XFX PRO 550W
Motherboard - MSI 970A-G43 Socket AM3+/ AMD 970/ DDR3/ SATA3&USB3.0/ A&GbE/ ATX Motherboard "
CPU - AMD FX6300 Black Edition 6 Core
Memory - G.SKILL 8GB (2x4GB) DDR3 1600 RAM
Any advice gratefully received.
Many thanks
Thanks for your help. Sapphire R9 280 Dual-X it is then.
