Video card help
owie
13
Okay need some help please? I have just recently upgraded my rig.
• Asus ROG Maximus VI Hero Z87 ATX LGA Socket 1150
• Intel Core i7-4770K Processor
• Corsair Hydro Series H110 Liquid Cooler
• Kingston Hyperx 120gb ssd
• Seagate 1TB Serial ATA HD 7200/64MB/SATA-6G (Back up and Games)
• Kingston HyperX Beast 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
• XFX Radeon HD 7970 Double D 3GB DDR5 X2 In crossfire
• CORSAIR Professional Series Gold AX1200 (CMPSU-1200AX)
• Win 7 Ultimate
So here is the issues my graphics cards running in crossfire I just don’t seams that I get the performance that I should be getting low frames rates in servile games?
1. Current Driver for the Graphics card I have used Both, Not really much improvement with either of them.
The 13.4 Catalyst driver (5/29/2013)
And 13.10 Catalyst Beta driver (09/05/2013)
• Assassins Creed 3 less than 60fps while playing
• Batman Arkham City less than 60 fps
• Crysis 3 Same thing
• Battlefield 3 runs good over 70fps
• Bio shock Infinite runs good over 70fps
• Total War: Rome II on average about 30 to 40fps
So are they just S*&t cards or what, so I have been Kicking around the idea of just buying a MSI N780 LIGHTNING GeForce GTX 780. And selling my AMD cards.
So my question is will I SEE A NOTASBLE PERFROMANCE INPROVMENT with this card over my AMD cards? And is it worth the money? Now first I need you to understand that I work a lot of hours and when I am home I just want to turn on my computer and game not really in to the over clocking thing a lot now I will OC my chip but other than that just want to game. Now if there is a simple fix for my current Graphics card that fine but really just want the performance sit down and go? HELP???????
Have u try running with just a single 7970 instead?in some games crossfire didnt really work great and just cause some stutter.i would go for a high end single card setup which should perform much better.also to add notes,SLI is better than crossfire if u still want to run dual cards.770 sli maybe
Depending on your resolution even 2 x Titans cannot maintain 60FPs in Crysis 3. What resolution are you playing at? also check your CPU & GPU temps while gaming and check if you CPU or 1 GPU or 2 GPUs are running at 100% load. It may be worth trying the 13.8 driver version.
