Video card Help
Kyle_8
what video card fits in a HP Desktop Computer 8000 Core 2 Duo 3.16GHz 4GB 1TB HDD Windows 7 Professional 64-Bit Product M# SL117UP#ABA I purchased for my son but it needs a video card & i need to know what type video card fits in this mini tower, I tried HP to no avail
Can anyone help ?
this one?
it has a pcie slot
you will be limited by that cpu and the power supply though
max i would put into it would be a gtx 750
make sure it is a version that runs off the power of the pcie slot alone ( no 6-pin from power supply required )
like this...
this one?
it has a pcie slot
like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487027&cm_re=gtx_750-_-14-487-027-_-Product
if that is the build id say for a graphics card with that little room i recommend a gtx 750 ti depending on your psu will depend on which brand you should go with but since theres such little room from what i can see its best not to get something like the msi gaming oc edition for that due to its size
