Question video card power setting question
Digicats
BANNED
Jul 19, 2014
117
9
10,595
Set it to Prefer Maximum Performance and set the refresh rate to Highest Available.
Optimal power just throttles the clock speed down when you're not using 3D applications. Saves a bit of power. Either way you should set your refresh rate to highest available.
packersfan036
1,531
19
5,795
ok done, and the refresh rate is 144 hz 1440p g-sync monitor the refresh rate is at 143 hz one off of 144
packersfan036
1,531
19
5,795
ok i set the refresh rate in the nvidia control panel to highest available
Reactions: Digicats
