Video Controller (not VGA compatible) fix [SOLVED]
Jun 20, 2018
Please help. I have 1 missing driver in device manager which is 'Video Controller' not (VGA compatible).
The display adapters are fine, no errors.
Also my GPU driver is up to date.
Here are my specs:
i5-7400
8gb ddr4
GTX1060 6gb
If anyone would help I would appreciate it. Thanks!
It's about bios I think.If the fans of the gpu still turning than we have this issue. Please instal ddu and make a driver clean up. And if you see your gpu at device manager, It's done. But if you dont see you gpu at device manager, than restart your pc over and over until seeing your gou in device manager
