Question Videocard - monitor issue
Jan 15, 2021
I have a 24 inch Philips monitor, an Asus rog strix B550-E gaming motherboard, and a Asus Radeon RX570 OC (8GB) video card. The motherboard and the videocard both connected to my Seasonic PSU. When I connect my monitor to the videocard with a HDMI cable the display says: "no video input".
Before that I tried the monitor with the hdmi cable on the laptop, it worked.
What could be the problem?
Jan 11, 2021
4
Hello,
Are you sure that you put the hdmi cable in the RX570 OC (8GB) video card? There is a possibility to make a mistake and put the cable in the integrated motherboard GPU. If this is the case, your monitor probably will have no signal. Check this.
