G
Guest
Guest
I have been using my monitor now for almost a year and it has worked fine untill literally this morning. I was using it this morning, nor problems. I left the cmputer on but turned the screen off to go for a cycle and when i returned 2 hours later, i pressed the button under the screen to turn it back on and it just started flashing the green light on making an odd buzzing.hissing noise.
The screen is not turning on at all and i have tried unplugging it from the wall and the pc. It seems that it has broken, or blown a fuse or something.
Has anyone else had a similar problem, or any suggestions? Thx
