Would that be the xg2402 ?
*AMD FreeSync™ technology is supported via DisplayPort and/or HDMI depending on the model.
Picked this monitor because I use a laptop (Acer Predator Helios 300) which only has an hdmi out on it. Most monitors only support 144hz through dvi so that was an issue for me. After a lot of research this was the most affordable monitor that supports both 144hz AND Freesync over hdmi (The...
Could be wrong but reading just now, the newer 2019 xg2401 model supports Freesync over hdmi? There's mention it does but the older 2017 model doesn't.
No, the XG2401 doesn't support FreeSync over HDMI which the Xbox requires.
Picked this monitor because I use a laptop (Acer Predator Helios 300) which only has an hdmi out on it. Most monitors only support 144hz through dvi so that was an issue for me. After a lot of research this was the most affordable monitor that supports both 144hz AND Freesync over hdmi (The older XG2401 dosent support freesync over hdmi). Works flawlessly, Colors are decent especially for the price and the stand is amazing and very adjustable. Perfect budget gaming monitor. Highly recommend especially if you might be in an oddball situation like myself.
Yeah i think so. I seen this but the they say the same thing for 2402. That's probably what they meant by model. I saw a review guy at Amazon mentioning 2019 version of the 2401
https://www.viewsonic.com/us/xg2401-2.html#reviews
Review at Amazon
https://www.amazon.com/product-reviews/B01A0ZRR50
Don't know what to believe but if want to make sure, get the 2402 model if you can.
5 Best Monitors with FreeSync Over HDMI of 2019
Unlike with G-Sync, some monitors support FreeSync over HDMI, which is great if you want a more versatile monitor and/or game on Xbox One consoles. However, shopping for the best monitors with FreeSync over HDMI3dinsider.com
That review is for the XG2402 (Amazon mixes reviews from different models because they are dumb)Yeah i think so. I seen this but the they say the same thing for 2402. That's probably what they meant by model. I saw a review guy at Amazon mentioning 2019 version of the 2401
Review at Amazon
Freesync / Adaptive Sync is part of the DP specification - maybe it has or will be rolled into HDMI - but I am not aware of it.Could be wrong but reading just now, the newer 2019 xg2401 model supports Freesync over hdmi? There's mention it does but the older 2017 model doesn't.
