I'm in the process of building a vintage PC to play older games, mainly DOS-based games, and I'd like your opinions on the hardware and performance and some advice on the performance of the system.
I'm using an ASUS P5S-VM(HP Pavilon 6640C) motherboard with an AMD K6-2 400AFQ, 256 MB PC100 RAM, and a Yamaha Labway LWHA151A00 ISA OPL3 soundcard.
It does not have an AGP slot, only PCI, but it does have integrated graphics, SiS530 with 8 MB(?) VRAM. Does anyone have any information on the SiS530, i.e. specifications? Clock speed, RAM clock, etc.
It seems alright for DOS games when using a slowdown utility, however when I try to play Windows-based 3D games, it struggles. For example, in Robot Arena, it requires a 266 MHz Pentium II CPU(450 recommended), 32 MB RAM(64 rec) and a DirectX compatible 3D graphics card with 8 MB VRAM.
Even on the lowest graphic settings at 640 x 480, the game stutters like heck and the CPU is constantly at 100%. I was forced to turn the graphics on the lowest as I was designing my bot, and the preview kept disappearing, I'm assuming due to VRAM.
I'm planing on eventually upgrading to a 500 MHz K6-2, and I'm getting a Nvidia GeForce 6200 PCI GPU. How much of a performance difference would I see between the PCI GeForce 6200 and the integrated SiS530? And would it make a difference to get another 100 MHz out of the CPU?
I know the K6-2 doesn't compare to a PIII, but at 400 MHz, what speed Pentium II/III would it be almost equivalent to?
Please reply soon, I'd appreciate any opinions, information, and advice.
